Cosworth YB ignition module issue
Old Sep 3, 2025 | 06:14 PM
d506gsg's Avatar
d506gsg
Default Cosworth YB ignition module issue
I am having an issue with no spark on my 2wd YB, I am only getting 3v at the ignition coil when cranking, if I measure accross the + terminal and the chassis earth I get 12v. I don't know if the ignition module is to blame, the "book" says I should get 800 ohm if I measure the pins on the module but I get around 35k ohm when I measure. The module is brand new (from ebay that is) can anyone help? TIA
Old Sep 4, 2025 | 03:36 PM
cossie2's Avatar
cossie2
Have you checked phase sensor under the distributor cap maybe wire is cracked...
Slyman
Nov 14, 2010 06:09 PM
TANGO_FSI
Aug 24, 2009 03:27 PM
drum1982
Oct 5, 2006 07:40 PM
Moonie
13
Aug 18, 2006 06:10 PM
Ryan
Jan 22, 2006 11:20 AM
