Big ends
Old May 17, 2025 | 10:00 AM
2much's Avatar
2much
Rs turbo owner
Default Big ends
this is my big ends after 1600 miles and 3 oil changes, lucky no marks on the crank. The one furthest from the oil pump is the worse.
I'm going to put another oil pump in it too but anyone got any ideas how they've worn so quick
luckily I caught it in time
Old May 17, 2025 | 01:25 PM
haz87's Avatar
haz87
Hopefully you've been monitoring or at least checked oil pressure before tearing it down, tho saying that what made you decide to open it all up at only 1600 miles?
Clearances or oil pressure/flow are really the only two things. DIY build or pro? If DIY, did you at least plasti-gauge it, and obviously ensure everything was torqued correctly (and wrench is calibrated!!)?
Old May 17, 2025 | 03:08 PM
2much's Avatar
2much
Rs turbo owner
Was rebuilt in a garage, before I had it. What made me take it apart was, I was getting a knocking noise underload like it was an 1.1 ohv
Old May 17, 2025 | 03:10 PM
2much's Avatar
2much
Rs turbo owner
I changed tappets and it didn't shut up. Maybe wrong oil as so many people use different oils, it started with 10w40 millers done 2 oil changes with that then I went to 10w60
2much's Avatar
2much
Rs turbo owner
No never monitored oil pressures too late now
Old May 18, 2025 | 02:22 PM
2much's Avatar
2much
Rs turbo owner
Since this had my friend up he checked the shells all was good, so took cam out and found that to be worn out so ordered a new one
Old May 27, 2025 | 11:25 AM
sierra3dr's Avatar
sierra3dr
can the pump be tweaked to increase pressure?
SWIFTY
17
Mar 5, 2009 05:49 PM
1.9 xr2 on 40's
Dec 22, 2007 04:14 PM
cossyjay
Jan 17, 2007 07:53 PM
lead_foot
Nov 13, 2005 05:17 PM
