Ford Focus RS, 2.3 front transfer case bolt holes
Old Apr 26, 2025 | 05:15 AM
Chili58's Avatar
Chili58
Default Ford Focus RS, 2.3 front transfer case bolt holes
Hi - the issue in front transfer case; the box where the driveline to rear separates: The box has five bolts. There are two sizes of holes for those bolts: 12 mm and 10 mm. Should the larger holes have a guides or not?
The box was removed at dealer's workshop to change the leaking seal at 130.000 km. Now - 140.000 kms it has been separated again and dealer says that some of the holes are worn to 12 mm; and they ask 4.000 eur/usd to replace it. No way; it can be fixed with 500 eur/usd. But I am curious, that did they forgot the guide tubes there at first place, or what has caused the leaking. The bolts were loosened by itself.
Cossy Mike
13
Mar 19, 2014 01:24 PM
12340987
Oct 21, 2011 12:16 AM
mrviper
Ford Focus RS
Jan 16, 2010 12:03 AM
fordrallycar
23
Dec 25, 2009 02:03 PM
DAN P
12
Oct 31, 2005 06:26 PM
