Focus st mk2 misfire
Old Apr 12, 2025 | 03:29 PM
Kevinthefisher's Avatar
Kevinthefisher
Default Focus st mk2 misfire
Hey there
I was after a little bit of help and advice on something if possible please
I’ve been trying to get to the bottom of a lumpy engine over the last year and I’ve decided I need to ask for help.
So it started with the rpms bouncing a bit and then started with a mild misfire.
So I tried the usual, sparks, coils, map, maf, check grounds, new battery and got no where. Did a vac leak test and sniff test, no issues. I had just had the cam belt and water pump done and they were done properly with the locking tool all timed right.
I got a code checker and had 1260 and 0017 which are for the pats and the cam crank correlation.
So I changed the cam sensor and vvt and got nothing. So I ordered a crank sensor and as I went to start it (on a warm day) it ran smooth. So I left it.
I went to start it on a cold morning and got the lumpy idle back. But as the day warms up the idle gets better. If it’s a cold day, it’s lumpy even if I try to let it warm up and sometimes stalls.
All temperatures on the car look good, ambient, coolant, oil and pressure. Just super lumpy on a cold day and runs good on a warm day. Could it be the crank sensor?
Any help would be greatly appreciated.
Thanks
OrionRST200bhp
16
Mar 14, 2024 11:26 PM
cosworth it
Aug 7, 2012 05:10 PM
sheerline
Ford Escort RS Cosworth
Jan 30, 2010 09:18 PM
bbspolo
23
Aug 24, 2008 05:16 PM
TurboInsania
Aug 10, 2007 09:38 AM
