mk6 fiesta pedal
Old Feb 27, 2025 | 06:52 PM
muzzman1's Avatar
muzzman1
Default mk6 fiesta pedal
Hi does anyone have a wiring diagram of a mk6 fiesta throttle pedal or the pin location of the wires
Old Feb 27, 2025 | 08:27 PM
GVK.'s Avatar
GVK.
Google says "For a Ford Fiesta MK6, the throttle pedal sensor (also known as the accelerator pedal position sensor or APP sensor) typically uses three wires: a 5-volt reference, a ground, and a sensor signal wire. Pin locations can vary slightly, but the general wiring is a yellow/orange wire from pin 5 on the APP to C1-A2 on the PCM, and a blue/grey signal wire (twisted with a yellow/green ground wire) from pin 2 on the APP to pin 1 on connector C12".
Old Mar 1, 2025 | 06:10 PM
muzzman1's Avatar
muzzman1
Hi the plug has 6 wires 2 feeds 2 grounds and 2 signal wires.
Old Mar 2, 2025 | 06:19 AM
GVK.'s Avatar
GVK.
Hmm, annoying I used to be able to get Ford wiring diagrams in my last job, don't work there anymore
Old Mar 4, 2025 | 04:50 AM
ronf42's Avatar
ronf42
Pin 1. 5v
Pin 2. 5v
Pin 3. signal
Pin 4. ground
Pin 5. ground
Pin 6. signal
Old Mar 4, 2025 | 06:04 AM
muzzman1's Avatar
muzzman1
Thanks for info
user 769729789
14
Apr 12, 2005 02:46 PM
