Sierra VIN Details
Sure, here decoded:
* = Constant asterisk
WF0 = Word Manufacturer Indicator (European vehicles)
E = Model Variant, seems like this is not from the Sierra
XX = Constant X
G = Product Source Company, Ford of Germany
B = Assembly Plant, Genk or Halewood
B = Model Range, B stands for Sierra or Mondeo, but digits 5, 11 and 12 doesn`t match with this, assuming that the VIN is from the Sierra, so I would like to say that the VIN is not from the Sierra
E = Model variant, seems like this is not from Sierra
E = Date of Manufacture - Year, seems like this is not from Sierra
E = Date of Manufacture - Month, depends what year car is manufactured
87262 = Vehicle Sequnce Number
digit 5,
B 3 door hatch back saloon, L for a Cabriolet, V for a van, A for a 5 door hatch back, C for a 2 door coupe, D for a 2 door estate, N for a 5 door estate and T for a 2 door saloon.
digit 10,
A is Escort, B is for Sierra and Mondeo, G for a Granada, E for a Capri and F for a Fiesta.
digit 11,
is just repitition from digit 5 of the what model of car it is
For the Sierra digits 5 & 11 shall be 5,B 11,B Saloon 3 door or 5,B 11,F Sierra 4 door saloon
XX = Constant X
digit 5,
digit 10,
digit 11,
Sure, here decoded:
XX = Constant X
digit 5,
digit 10,
digit 11,
XX = Constant X
digit 5,
digit 10,
digit 11,
Thank You very much Zigu! 🙏
The most Important thing would be, which engine the car has, because the Design is completely XR4i, but the car has 2.0 Pinto EFi also in the Papers but the owner is telling 100%, the car had 2.8 V6 and its an original XR4i.. ..
Also in your picture Engine code is NE. Sierra Cosworth shall have N5.
Found this from the internet for NE:
N stands for 2 ltr
E stands for High Compression+increased performance.
Not sure what kind of engine it`s.
Drive cond box you have A, which means that car is LEFT-hand drive.
N stands for 2 ltr
1984 Ford Sierra XR4I
VIN: WF0BXXGBBBDP(hide last digits)It has digits 5 and 11 B. But as posted earlier found also 3 door Sierra with digit 5 and 11 E. I hope someone answer what E stands in the digits 5 and 11.
I hope also that someone in here, who has real XR4, can check presented VIN and the engine code.
This VIN can only provide basic information, and this requires access to the database, as the VIN itself is useless without decoding.
You can use the window sticker privacy feature at https://carfast.express/en/window_sticker to find out what options were originally installed and ensure everything matches the documentation.
This will save you time and eliminate the need to call the dealership or search for paper documents. It will also eliminate confusion with replacing parts and allow you to inspect the car before buying or selling.
I see this original post is from a while ago.
The break down of this chassis plate WF0EXXGBBEEE87262
WF0 = Word Manufacturer Origin - WFO - Cologne Germany
E = Body Type - E - 3 Door Hatchback
XX = Constant X
G = Product Source - G - Cologne Germany
B = Model - B- Taunus/Cortina/Sierra/Mondeo
E = Date of Manufacture - Year - E - 1984
E = Date of Manufacture - Month - I don't have this information prior to 1985
87262 = Vehicle Serial Number
Drive - A - LHD
Engine - NE - 2.0 HC (engine block code NET)
Trans - D - Auto (Type C3)
Axle - V - 3.38
Trim Garn - QK - Q steel Grey - K unknown (by me)
Type BED-20-4 - BED - 3 door hatchback (3 pillar) presumably 20-4 - 2.0 litre 4 cylinder (but I don't have that information)
Colour B 3 - B - Diamond White - 3 - 83 paint model year
XX = Constant X
Drive - A - LHD
Axle - V - 3.38
XRtwo_1,8 zvh
20
Feb 13, 2011 05:39 PM
scoooby slayer
Jul 8, 2009 06:15 PM
