smax 1.5 turbo bypass valve
Old Dec 27, 2024 | 09:31 AM
ACN70's Avatar
ACN70
Default smax 1.5 turbo bypass valve
morning, does anyone know where the turbo bypass valve is on 2019 SMax 1.5 turbo, error code P0034 and no currently driving with no Turbo
Old Apr 23, 2025 | 02:16 PM
ohmygod's Avatar
ohmygod
Man, you asked your question about the S-Max a year ago and no help? Did you feel like in a haunted museum? Anyway, I had a similar issue with my 2019 Mustang GT last year — first got a P0034 error, then the boost just disappeared, felt like I was driving a weak V6. Thought it was the bypass valve, checked it — all good. Turned out to be a classic Coyote problem — broken valve spring can you imagine? Just one. It caused the valve to stay slightly open, messed up the pressure in the manifold, and the ECU assumed the turbo was acting up. Took a while before it even threw a P030x misfire code. Ended up replacing all the springs around $26 for each.
conor.rst
Nov 18, 2009 03:31 PM
wimble
Feb 5, 2008 06:19 AM
fast_ford_uk
Jun 2, 2007 11:29 AM
4x4
Dec 19, 2006 10:19 PM
