ST170 front suspension
Old Dec 3, 2024 | 02:32 PM
Tool1312's Avatar
Tool1312
Default ST170 front suspension
The front left suspension on my ST170 makes a clonking noise on turning, suggesting either a broken spring or knackered top mount bearing.
Now considering replacing either individual part would still require removal of the strut anyway, would it be just as easy to replace the entire upright with a full assembly, as presumably the labour cost would still be the same? Obviously both sides would need doing at the same time.
Also, if I'm sourcing the uprights myself, are the ST170 springs different to normal MK1 springs, as in lowered
roflhat
Ford Focus ST
Mar 1, 2017 05:07 PM
waxintaxin
Ford Focus ST
Jun 21, 2012 01:58 PM
kyle_st200
Jan 21, 2011 12:15 PM
LewisST170
Ford Focus RS
Feb 15, 2010 12:04 PM
