Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
earth issue
Old Jul 31, 2024 | 01:19 PM
Phantom101's Avatar
Phantom101
Default earth issue
i guys
i have a 2016 focus 1.5 diesel now the last few months i have noticed the car started to run on after shutdown with no dash lights saying anything was wrong. i thought nothing really of it but it started to sit in the back of my mind then i lately i got a engine service now on the dash so i plugged in forscan and got codes that that where out for the fault throttle body stuck open. i changed that and not the result i was looking for. so i tested all wires going to the motor and sensor and the seemed fine all giving proper readings so i though did a relearn of the throttle body still the same so i went back over the wires and found that when the ignition is on the earth to the throttle body has high resistance but when i turn the ignition off and the car goes into sleep mode the earth is perfect turn it on and high resistance again is this normal ?? it goes against my brains thinking. if im right is the PCM going bad it dose the same to the MAP sensor earth as well
thanks for taking the time to read
Phantom
Old Aug 1, 2024 | 11:27 AM
Phantom101's Avatar
Phantom101
an example of whats going on
Heitmann
Jun 1, 2020 11:39 PM
Adam.
18
Mar 31, 2011 03:23 PM
Hansenturbo
Aug 10, 2007 04:10 PM
JjCoDeX75
34
Jan 27, 2007 11:37 AM
