Ford Mondeo Mk1, does it have a hydraulic or aable clutch, also, is pressure plate...
Old Dec 25, 2023 | 05:59 PM
berni29's Avatar
berni29
Default Ford Mondeo Mk1, does it have a hydraulic or aable clutch, also, is pressure plate...
Hi There
I have googled this to death but seem not to be able to find a definitive answer.
Ford Mondeo Mk1, does it have a hydraulic or cable clutch, also, is pressure plate self adjusting?
I am mating a type 9 box up with a 2.0 Blacktop Zetec, 1.8 Flywheel, Mondeo 1.8 Mk1 clutch cover and friction plate, using a Burton Power type concentric slave. This will only work in the long term if the clutch (cover) is self adjusting.
Many thanks
Berni
Old Dec 25, 2023 | 09:49 PM
BIG LEE's Avatar
BIG LEE
Hi wont work altho people say it does... ive tryed it myself you will end up with really long clutch peddle ive got a mk1 mondeo zetec clutch new boxed hence i know lol...
You will be better off getting a redrilled 1800 silvertop flywheel and usen pinto or cvh clutch
Old Dec 25, 2023 | 10:15 PM
berni29's Avatar
berni29
Hi Lee
Thanks for the reply.
I have my CSC set up with a 19mm spacer and the release bearing is just touching the pressure plate fingers. It works perfectly, disengages early and is light. But my issue is that if the clutch cover is not self adjusting (SAC) then the fingers are going to move towards the CSC over time and the clutch will slowly disengage then slip because the CSC is already at full retraction. With a smaller spacer, say 12mm then I would have 7mm of retraction to play with but would loose 7mm of slave travel. Plus I would have to buy and fit a smaller spacer. If the cover is an SAC then the fingers stay static during the life of the clutch and happy days.
I asked if the Mk1 Mondeo clutch is hydraulic or not because most modern hydraulic systems use a SAC pressure plate.
Is the Pinto cover self adjusting?
All the best
Berni
Old Dec 25, 2023 | 10:58 PM
BIG LEE's Avatar
BIG LEE
hi mk1 mondeo is cable clutch im sure all mk1s are the mk2 mondeo isnt tho
Old Dec 27, 2023 | 06:53 PM
berni29's Avatar
berni29
Hi
I have done some experimentation with an old Zetec flywheel and clutch, and with a standard the clutch cover we are looking at about 7mm (max) movement of the clutch fingers over the life of the clutch.
It seems the clutch cover does not self adjust.
So the spacer required would be 12mm for this set up.
Berni
Tommelom93
Jul 21, 2019 09:02 PM
kyaki
Mar 22, 2017 10:09 PM
Mk4 Rick
Feb 10, 2013 10:46 PM
