BIG Resto Incoming :D
Old Dec 17, 2023 | 01:23 PM
K9 JSB's Avatar
K9 JSB
Default BIG Resto Incoming :D
New member and first post on Passion Ford
We pulled our Escort Cosworth out of storage after 20 years for a FULL and complete restoration. So theirs going to be lots of posts and dumb questions..
Along with the restoration we’re looking at upgrading several areas along the way. Aiming for 400hp, AP’s, Quaife diffs, lightweight flywheel etc etc
Coil-overs seem to be the first point of contention. Searching the internet it seems a common consensus is unless your Cossie is going on track (which it won’t be), there isn’t a good set of comfortable/All round coil overs available. I’m hearing Gaz coil overs are harsh and prone to shitting themselves, KW have the perfect “Street Comfort” range but non of their coil overs are available for older cars and regardless of what Ohlins does or doesn’t have available, they’re coilovers cost the EARTH.
SO…
Looking for you guys’es opinions, stock setup.. maybe with new springs? Is there a holy grail of street coil overs. What have you boys gone with? Any input greatly appreciated
Old Dec 17, 2023 | 03:37 PM
jonfoc's Avatar
jonfoc
There’s absolutely nothing wrong with coilovers as long as you spec them for your intended use
Old Dec 17, 2023 | 06:29 PM
james kiely's Avatar
james kiely
probably the the best bet at the minute is the blackart specced coilovers by mark shead at ma developments for a fast road car.specifically designed and engineered for a escos
looking forward to the resto
Old Dec 20, 2023 | 11:28 AM
Rsmat's Avatar
Rsmat
Best way I've found is to have the car corner weighted then give those details to Gaz and have them do the valve rates and spring rates to suit
I did this with my Rs Turbo and the ride / comform is way better than Koni was yet goves me plenty of support in the bends .
Old Dec 20, 2023 | 12:31 PM
jonfoc's Avatar
jonfoc
I wouldn’t fit Gaz to my wheelbarrow but each to their own.
Old Dec 20, 2023 | 01:02 PM
K9 JSB's Avatar
K9 JSB
Seemingly, a lot people with this opinion.
Is anyone aware of a good, off-the-self KW or Ohlins?
Old Dec 20, 2023 | 03:48 PM
jonfoc's Avatar
jonfoc
Both of those makes are very good. KW are good to deal with and can spec out your own requirements. Ohlins again have great reputation, Mick Gardner up in Barnsley will guide you through them. It all depends on what you want to use the car for. Ideally you want the dampers to be specific to your use. A fast road spec set up will be out of its element on track and a track spec will be horrific on road. You can get a large amount of adjustment in the unit and then change your spring rate when needed. But ideally you want a single spec set up to get the best out of it.
I used to work at Leda a few years ago. They have the capability of making you 4 way adjustable with remote canister etc but Roger the owner will talk you out of it and explain exactly why. I’ve had a few sets over the years and I will only use them when I can. All of their products are bespoke to the owner and vehicle.
Old Dec 20, 2023 | 05:31 PM
james kiely
leda are top notch
Old Dec 20, 2023 | 06:28 PM
jonfoc's Avatar
jonfoc
leda are top notch
You know it makes sense young man. I hope you’re well my friend.
Old Dec 20, 2023 | 07:05 PM
james kiely
i loved the way my mk4 track car went with the ledas jon .
all good mate
Old Dec 21, 2023 | 03:40 PM
Adam-M's Avatar
Adam-M
Black art design are meant to be as good as Ohlins. I have Gaz golds on my cossie which i don’t rate and ohlins on my evo, Ohlins are superb.
jag21
Aug 2, 2008 09:41 PM
MAD EVO 4
Apr 8, 2008 08:10 PM
vx220
18
Sep 6, 2006 05:47 PM
Lemon S2
Apr 12, 2006 03:35 PM
