Sierra door lock
Hi my 92 ford sierra has been sitting about a while in storage, now when I lock the car with the key you can't remove the key. The car is locking all doors but you can't remove the key. When you unlock it the key comes out again. When locked from passengers side the key comes out OK.
Before I start stripping it down incase i dont need to has anyone had this problem before. Is it likely to be the door lock or solenoid not letting it turn just fully or something or is their adjustment in rods or anything.
