Cosworth won't rev
Old Oct 6, 2023 | 01:01 PM
dillon5587's Avatar
dillon5587
Default Cosworth won't rev
Hi I have a 89 sapphire that won't rev past 5k it's misfires then drops the revs a bit then goes again up to 5k same again, normal driving is fine any help appreciated thanks
Old Oct 7, 2023 | 06:06 PM
james kiely's Avatar
james kiely
sounds like it might be over boosting
Old Oct 8, 2023 | 12:08 AM
dillon5587's Avatar
dillon5587
cheers for the reply the car has been laid up for 9 years, I re gapped the plugs today and I think it has got worse, it coughs and splutters under normal driving, they r new plugs they wer @ .68 and I re gapped them to .8 I think I will go back to .7
Old Oct 8, 2023 | 11:51 AM
james kiely
you need to do a full recommission on the car , clean out the fuel tank clear lines, and stick a new timing belt on ., plugs. , clean all connections, check your voltage at the pump etc .
way too easy to fook an engine up
Old Oct 14, 2023 | 08:46 AM
cossynut2's Avatar
cossynut2
10 Year Member
I agree with you James, the chances of the car running right after being laid up for 9 years without doing all the usual checks etc is pretty near zero!
Old Oct 14, 2023 | 08:26 PM
qed296's Avatar
qed296
Its definitely not a turn key situation.
I'd be cleaning checking and replacing as much as possible prior to any thoughts of driving it.
MalteseFalcon
Ford Escort RS Cosworth
Oct 5, 2008 08:23 AM
MalteseFalcon
Sep 19, 2008 08:26 PM
JanDK
May 15, 2007 11:23 AM
Cossy Chris
Mar 23, 2006 02:28 PM
G2 FSR
Aug 9, 2005 06:48 PM
