Cossie engine mounts
Old Sep 2, 2023 | 04:55 PM
Rodge.'s Avatar
Rodge.
Default Cossie engine mounts
Anyone know what engine mounts are on a standard 3 door Cossie?
Just removed my old ones to fit a set of Collins ones but they seem to be quite harsh on tickover and low revs .
I's assuming I've not made an arse of fitting them tbh as they look straightforward!
Looking at the old ones, they look different - the numbers are 85HF-6038-DA and 85TF-6038-BA
So which one goes on which side?
Old Sep 4, 2023 | 01:06 PM
charlie luciano's Avatar
charlie luciano
Note to one’s self when you remove anything label it so you know where it goes should you need to put it back in its original place
did the Collins ones look the same? If they differed there is a chance they would have been sided, fit specifically to sides.
as for the harshness you’ll find a lot of the replacement/upgraded stuff is made out of different material and cause the car to feel different. I fitted a roll restrictor to my focus rs and it vibrated like a bitch when I first drove the car after it was fitted, so much so I thought I wouldn’t be able to live with it and thought about taking it off. It has settled down though but it’s still noticeable especially when the air con pump is running
Old Sep 4, 2023 | 01:47 PM
Rodge.'s Avatar
Rodge.
I did mark them but after looking around, I think one of my old mountings might be the wrong one anyway
Found this listing on Ebay - both mountings the same part number in the advert , mine are 2 different part numbers. Been like that for years
https://www.ebay.co.uk/itm/155747195...mis&media=COPY
On mine, the longer threaded rod is reversed on the other mounting.
Confused.com
Old Sep 5, 2023 | 06:40 PM
charlie luciano
Someone probably put a like replacement in for one of your originals that’s why they differ in appearance and part number
if the upgraded ones were the same leave them fitted and see if vibration settles down a bit
Old Sep 23, 2023 | 05:36 PM
scoooby slayer's Avatar
scoooby slayer
If I remember rightly left and right are different engine mounts as the locating pin is in a different place, on stock mounts that is.
I have Collins engine mounts in mine, they are stil harsh some vibration but they are miles better than the vibratechnics that I took off, I dont know how rod lived with it it was horrendous knock ya fillings out bad 😂🤣😂🤣
​​​​​​Collins still firm but it's bearable imo
Old Sep 25, 2023 | 07:56 AM
Rodge.'s Avatar
Rodge.
Thanks. I ended up just putting a standard set back on, must be getting old lol.
I'll just sell the Collins ones on Ebay or something, probably won't bother using them.
Old Sep 25, 2023 | 09:13 AM
scoooby slayer
I can't remember driving a cossie on stock engine mounts it must be 10 years ago now mate
Have you noticed a huge difference in vibration in the car going from Colin's back to stock ?
I've only gon vibra to Collins which is massive improvement but do still have small amount of vibration
Old Sep 25, 2023 | 09:23 AM
Rodge.'s Avatar
Rodge.
Yeah, the vibration basically disappeared after refitting standard mounts.
I took the Collins ones off and refitted them a couple of times although I can't see how it would be possible to fit them wrongly with the longer threads at one end.
The extra harshness from the Collins mounts was probably something I would have lived with 20 years ago but the car drove so well before, it seemed a shame to change it.
Oh well
Pic of the car in case anyone is interested sometimes use it for the school run, my wee girl loves it
Old Sep 25, 2023 | 12:31 PM
scoooby slayer
Oh well
Car looks lovely mate I had a moonstone years ago 🥰🥰
I can't run passengers side stock mount as it won't fit due to dry sump pump, but I can run a stock drivers side so I might try that for abit less in car vibes, I'm 43 and definately likeing abit more creature comfort lately 🤣😂 lol
Alps Pacino
May 20, 2007 05:25 PM
lmans123
Jul 13, 2006 09:28 PM
Daveyraveygravy
11
Oct 27, 2005 06:26 PM
rapidcossie
Jul 8, 2005 03:46 PM
escort-cossie-owner
Aug 29, 2004 02:54 PM
