Wasted spark coil pack
Old Aug 22, 2023 | 06:13 AM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Default Wasted spark coil pack
Morning,
does anyone know of the standard fiesta Rs turbo coil pack is wasted spark or do you have to buy a specific one?
cheers
Blake
Old Aug 22, 2023 | 01:25 PM
XR2's Avatar
XR2
Originally Posted by BlakeMoyle
Morning,
cheers
Blake
It is.
Specific one... depends on what you're planning to do.
Old Aug 22, 2023 | 07:07 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Originally Posted by XR2
It is.
hi mate
thanks for the reply, I’m converting to efi using a link management system they have said to get a frst wasted spark coil pack. Just wasn’t sure if that just meant a standard one?
Old Aug 22, 2023 | 07:36 PM
XR2's Avatar
XR2
The Ford coil packs didn't have an ignition amplifier. So when your ECU doesn't have one, you'll need either an amp module or a coil pack with a built in amp.
Old Aug 22, 2023 | 07:47 PM
boost monster's Avatar
boost monster
I found this out when I converted mine last winter and didn’t have a spark🙄
My mapper recommended a VW coil pack if you want one with a built in amp but I don’t know from which model.
Old Aug 22, 2023 | 07:53 PM
XR2's Avatar
XR2
You can also use an EDIS module. There's been some used as a standalone ignition system with a built in ECU and some that were just an amp.
The VW twin coil pack was probably one like the NGK 48010, used in hundreds of Audi/VW/Skoda/Seat vehicles.
Old Aug 22, 2023 | 09:37 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Thanks for the replies, I have purchased 2x cosworth ignition amplifiers which the tuner put on my list of find it items, so with that in mind do I just get a normal coil pack?
shanrico
Escort MK 5 / MK 6
Oct 14, 2022 06:56 PM
muz
35
Jul 23, 2016 11:10 PM
Matt Baxter
Oct 1, 2007 10:13 PM
gingeRS
Apr 4, 2007 08:57 AM
Damienholmes
May 16, 2006 06:46 PM
