Oil feed pic from block to turbo yb advice
Old Aug 5, 2023 | 04:53 PM
Robzilla's Avatar
Robzilla
Default Oil feed pic from block to turbo yb advice
can I have some advice please, is this the oil feed to the turbo
Old Aug 5, 2023 | 05:32 PM
james kiely's Avatar
james kiely
turbo oil should come off your oil pressure switch .looking at the size of that an fitting it looks more like a oil return from a breather setup
the oil then drains into the sump under your turbo
Old Aug 5, 2023 | 09:00 PM
Robzilla's Avatar
Robzilla
I have a return to the sump under the turbo, this fitting was put in when engine was rebuilt, I thought it could be an output to turbo. I have this fitting also that I don’t know what it’s for!!
Old Aug 5, 2023 | 09:19 PM
james kiely
yes that fitting will be your turbo oil feed and a oil pressure switch to your dash.the feed goes up between your engine and bulkhead and has a couple of p clamps to your head above the exhaust manifold and then into your turbo.
is your engine 2wd or 4wd?
​​​​​​https://mattlewisracing.co.uk/produc...-oil-feed-hose 2wd
have a look on the burton website and you will see the differences
Old Aug 5, 2023 | 09:29 PM
james kiely
have a look at this thread
https://passionford.com/forum/ford-s...-oil-feed.html
Old Aug 5, 2023 | 10:18 PM
Robzilla's Avatar
Robzilla
4wd block with a 2wd head, not sure the head would make any difference. I have got a hose from Burton but fittings are too big on the hose , I only have an-6 on the pressure switch , looks like an-8 on the other one
Old Aug 5, 2023 | 10:31 PM
Robzilla's Avatar
Robzilla
Does it go in this inlet ?
Old Aug 5, 2023 | 10:46 PM
james kiely
yep ,thats got the same AN fitting as you have on your fitting where your oil switch goes
Old Aug 6, 2023 | 07:10 AM
Robzilla's Avatar
Robzilla
great, thanks, one step closer lol
leo_cos
Nov 7, 2011 09:57 AM
cossiedrift
Jan 24, 2010 05:18 PM
AJ Escos
21
Nov 21, 2004 08:24 PM
