Installing electric pump in mk2 xr2
Old Aug 5, 2023 | 10:18 AM
roger69's Avatar
roger69
Default Installing electric pump in mk2 xr2
After renewing fuel sender in tank the fuel Syphons back to the tank after a few days, so I have to suck it up manually , which is a pain. So I decided to install an electric one, so can I pipe through the existing mechanical one or will I need to go direct to the carb..Only I was thinking maybe I could put a switch on it to turn it off once it has started and the Manuel pump could take over and save the electric pump.
Old Aug 5, 2023 | 05:42 PM
BIG LEE's Avatar
BIG LEE
you should just run a electic pump little facet would do job no trouble
wenmoll
May 2, 2020 11:20 AM
SaqsS2turbo
17
Apr 25, 2008 04:37 PM
raw16
Dec 1, 2007 09:05 AM
cosworth_wannabee
Apr 17, 2007 12:01 AM
cosworth_wannabee
Apr 16, 2007 11:23 AM
