Newbie needs advise/help. Duratec turbo
Old Aug 1, 2023 | 08:22 PM
Fraz1's Avatar
Fraz1
Default Newbie needs advise/help. Duratec turbo
Hi foks, straight to the point, I have a 2005 pre facelift 3 door mk2 ford focus currently with the 1.6 engine in it, it's my daily driver and with me being a petrolhead it's also my hobby/project, i also have an MTX75 gearbox from a 2007 2.0 duratec focus and a 2.0 duratec engine, loom, ecu, keyfobs and instrument cluster from a 2007 fiesta st150 which i want to turbocharge and put into my focus to replace the 1.6, i assume that since the mk2 focus was available with this engine and gearbox then it should drop straight in to the same mounting points, i am also aware that the power steering, coolant pipes etc will need modified, what i need to know is.....
1.will the fiesta ecu and instrument cluster work in the focus bearing in mind it came out a facelift st150 so the cluster is the same size and shape as the focus,
if no then what do i need to do to make it run in the focus?
2. where would i get a turbo downpie and CAT for a 2.0 duratec turbo in a mk2 focus?
I plan to just get the engine in the car running N/A just now, i'll worry about the turbo stuff later.
Thanks in advance
Fraz1
May 4, 2023 09:10 PM
cor 1600e
Oct 16, 2017 01:56 AM
woolford
Ford Focus RS
Apr 24, 2011 08:24 PM
Fjay
11
Jun 5, 2008 09:06 AM
