Escort RS1600i This forum is for all things about the Escort RS1600i
RS1600i Crank Position (Flywheel) Sensor wanted
Old Mar 5, 2023 | 12:48 PM
deen_eeen's Avatar
deen_eeen
Default RS1600i Crank Position (Flywheel) Sensor wanted
Hey guys,
My flywheel sensor has done it's job until 2 days ago and decided to just burst into pieces.
Now I am searching for a "new" one.
Are there maybe alternate sensors known that can be used instead of the oem one?
Also, has maybe one of you a picture showing that extra tooth that is providing the signal to the flywheel sensor?
I couldn't find it on my flywheel.
Hopefully one of you can help me out here.
Thanks in advance,
Mike
Old Mar 5, 2023 | 04:12 PM
BIG LEE's Avatar
BIG LEE
Originally Posted by deen_eeen
Hey guys,
Thanks in advance,
Mike
hi you can get copy aftermarket sensors but there junk tbh on like ebay...
id try finding new ford or good brand like bosch etc...
Old Mar 5, 2023 | 04:13 PM
BIG LEE's Avatar
BIG LEE
the signal it from a hole missing if you like there isnt a peg or anything like on escorts etc its holes or dots in flywheel
Old Mar 6, 2023 | 06:19 AM
XR2's Avatar
XR2
Hey guys,
Thanks in advance,
Mike
The RS1600i was a car built for Group A motorsport purposes and was the first production Ford that came with a computer controlled wasted spark ignition. Back in the days this was (mostly) a very new technology and there weren't many manufacturers using such ignition systems. That's why they all usually used individual solutions for sensors, ECUs and other parts. I've never seen an aftermarket CPS for the RS1600i. And I'm sure these aren't available as new old stock at Ford (part no. 9059041).
So you've got three options:
1. be patient and look for a good used sensor
2. convert the car to mechanical XR3i distributor (worst decision)
3. Use an aftermarket ECU and an external CPS setup that bolts to the oil pump. Burton sells these.
When you're looking for a missing teeth (or cut-outs like the later EFI CVHs and Zetecs had) on your flywheel, you won't find them. The RS1600i CPS uses the starter ring gear. And there's one teeth plated with a special metal so the ECU knows where the TDC is.
Old Mar 6, 2023 | 11:31 AM
deen_eeen's Avatar
deen_eeen
Default Thank you
Alright thank you guys for the answers, I will check out the things you proposed and see what I will do.
Best regards,
​​​​​​Mike
Old Apr 3, 2023 | 03:54 PM
boost monster's Avatar
boost monster
Check my local guy out, he’s had the same issue.
https://www.facebook.com/MVTURBOS/
Old Apr 3, 2023 | 03:55 PM
boost monster
Looks like you can’t post Facebook links.
search MV Turbos
garypara
Escort RS1600i
Jul 22, 2019 01:56 PM
johnnysash
Escort RS1600i
16
Dec 29, 2012 03:14 PM
xr3iturbo
Dec 4, 2005 08:33 PM
