Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Fueling issue
Old Feb 28, 2023 | 05:57 PM
Lee read's Avatar
Lee read
Rs turbo
Default Fueling issue
Hey guys so I've rebuilt my wife's engine all fresh ect. It's taken 3 years I know a hell of a long time. Connected everything up she turns over but not firing. So I assumed spark so got new spark plugs, on taking the old ones out they where bone dry. (New ones in anyway) I depressed the Schrader valve on the fuel rail to see if there was pressure. She squirted out. What can I check next?
Kind regards
Old Feb 28, 2023 | 06:48 PM
GVK.'s Avatar
GVK.
Power/ground to injectors?
Old Feb 28, 2023 | 07:54 PM
Lee read's Avatar
Lee read
Rs turbo
What do you mean mate? May have missed something out here
Old Feb 28, 2023 | 09:11 PM
GVK.'s Avatar
GVK.
Check for power - check for ground from ECU, ideally get a noid light kit they're checp off ebay, simply plug the injector in in turn and crank the car, the noid light will flash if the ECU is switching the injectors.
Old Mar 1, 2023 | 07:57 AM
Lee read's Avatar
Lee read
Rs turbo
Thank you will get one of those and give it a check.
Old Mar 1, 2023 | 03:44 PM
GVK.'s Avatar
GVK.
Worth checking all the wiring you've had disconnected to see if there's any pins pushed in /bent also.
Old Mar 5, 2023 | 11:07 AM
Lee read's Avatar
Lee read
Rs turbo
Il get on checking all of them. So I did get a new crank sensor and I didn't actually put it back on. So it's on now still nothing. Checked to see if there was a spark. Couldn't see one and the bottom of the pugs still looked dry. I'm going to drain the fuel out of it as it's 3 and a half years old and clean the mesh/gauze. Also do you know what this wire is as I can't figure out what it's for.
Old Mar 5, 2023 | 04:36 PM
GVK.'s Avatar
GVK.
No idea sorry
Old Mar 10, 2023 | 01:31 PM
Lee read's Avatar
Lee read
Rs turbo
No idea sorry
Ok mate thanks. What's the easiest way to get to the fuel pump?
Old Mar 10, 2023 | 03:49 PM
Lee read's Avatar
Lee read
Rs turbo
Also put the noid light on in the connection on the far left on the injector rail and there was no light. What would be the prognosis on that? I assume ECU is fucked
Old Mar 10, 2023 | 04:45 PM
GVK.'s Avatar
GVK.
With the noid light, if when cranking there's no light you need to see if there is power going to the injectors with a test light/multimeter.
the ECU will carry out the ground, if the ECU is ok.
Old Mar 10, 2023 | 04:51 PM
Lee read's Avatar
Lee read
Rs turbo
Where will I use the multi meter? I.e test the ECU? Not the best at electrics
Old Mar 10, 2023 | 07:37 PM
GVK.'s Avatar
GVK.
There's 2 connections on each injector wire, live 12v+ then the other is switched ground by the PCM/ECU Need to check that one is power when cranking if you have power then check with the noid light the ECU switching when cranking , if the noid light does not flash at all when cranking you really need a wiring diagram to see where the fuses and relays are.
I'm sure with a bit of you tubing you can find step by step guides how to do it.
Looking again at that wire looks like a ground wire thats snapped/corroded off , see where it reaches you'll find where youve snapped it off from .
Further than that you;ll need to get the fault codes rread, might give you more of a clue, but be weary that there maybe lots of codes that have been man made during your 3 yrs job.
Old Mar 11, 2023 | 10:37 AM
Lee read's Avatar
Lee read
Rs turbo
​​​Further than that you;ll need to get the fault codes rread, might give you more of a clue, but be weary that there maybe lots of codes that have been man made during your 3 yrs job.
[QUOTE=GVK.;6834192]There's 2 connections on each injector wire, live 12v+ then the other is switched ground by the PCM/ECU Need to check that one is power when cranking if you have power then check with the noid light the ECU switching when cranking , if the noid light does not flash at all when cranking you really need a wiring diagram to see where the fuses and relays are.
​​​you are talking about those connections to the injectors aren't you mate. And looking at the broken wire it seems like it's a broken ground. Not 100% sure where it goes though..will have to dig around on that
Old Mar 11, 2023 | 01:18 PM
Lee read's Avatar
Lee read
Rs turbo
Also found the broken earth wire. Connects to the side of the gearbox so will be getting that sorted now
Old Mar 11, 2023 | 06:01 PM
GVK.'s Avatar
GVK.
Yeah the injector plugs look like that.
Old Mar 13, 2023 | 06:22 PM
Lee read's Avatar
Lee read
Rs turbo
OK so illve had a quick look. Put the multi meter on the injector harness and nothing. So check a few connections and nothing looks bent or anything. I put my scanner on and it came up with cam position sensor no signal so cleared it off and it tried to start then just carried on to turn over but still trying a little bit but same fault code P1345. Changed the sensors from a spare engine I've got but much the same.
Old Mar 13, 2023 | 07:51 PM
GVK.'s Avatar
GVK.
You've probably got no feed to the cam sensor wiring if you've tried sensors
Wasn't an ST but was a mk2 Focus, I had a problem with it kept blowing a fuse that fed the VCT solenoids and coil, had a shorted out wiring harness on top of the gearbox.
Check all fuses!
Old Mar 13, 2023 | 07:57 PM
GVK.'s Avatar
GVK.
Looks like P1345 could be a cam/crank correlation code as well, did you use the proper tool to set the cams?
Did you get the non signal code descripton from scanner?
Old Mar 13, 2023 | 09:23 PM
Lee read's Avatar
Lee read
Rs turbo
I did read that too. I didn't use a cam tool. Everything was marked up. I'm thinking I'm guna need to buy one. Ye the code was from a scanner.
Old Mar 13, 2023 | 09:30 PM
GVK.'s Avatar
GVK.
Did you fix that broken earth wire.
Seems like you have a few issues that will stop it starting, difficult to fix from afar! I used to live nr Worcester J7 M5 so not too far frm Kiddy. Shame I wasn't nearby now!
Old Mar 13, 2023 | 10:06 PM
Lee read's Avatar
Lee read
Rs turbo
That is a shame. Ye I'm just waiting for a new bolt to hold it on properly. Think il have to go through the wiring and check all the connections. And I think il get a proper timing tool too. Just expensive
Old Mar 14, 2023 | 01:10 PM
Lee read's Avatar
Lee read
Rs turbo
And assuming there's no signal there is no power getting to the sensors!!??
Old Mar 14, 2023 | 08:13 PM
GVK.'s Avatar
GVK.
Exactly but you need to test the wires, like I posted before check all the fuses, start with the basics.
Old Mar 14, 2023 | 08:55 PM
Lee read's Avatar
Lee read
Rs turbo
All fuses are good. Checked all of them. There is a connector I came across whilst putting the new crank sensor ok.
so it's the one that's circled. It spurs of after the crank sensor connector.
Old Mar 14, 2023 | 10:03 PM
GVK.'s Avatar
GVK.
Have you had the gearbox out too? Reverse light switch maybe?
Old Mar 14, 2023 | 10:06 PM
Lee read's Avatar
Lee read
Rs turbo
I did have the gearbox out as it was easier to get it all back together and slot it in. Will have to have a look at that. But I think your right there mate.
Old Mar 14, 2023 | 10:22 PM
GVK.'s Avatar
GVK.
If I remember, the reverse switch is under the shifter where the gear cables go on.
Old Mar 16, 2023 | 06:33 PM
Lee read's Avatar
Lee read
Rs turbo
Yes mate your right. All connected. So I've put new cam sensors on and I checked with a multimeter to the cam sensor and it came up with a reading of minus 1.12 to minus 2. Something.
Old Mar 16, 2023 | 08:00 PM
GVK.'s Avatar
GVK.
Without a wiring diagram its hard to say wht each terminal should read on the cam sensor, how many wires is there?
Old Mar 17, 2023 | 10:58 AM
Lee read's Avatar
Lee read
Rs turbo
I've got a whole PDF of wiring but I don't know how to send it over here. My mate sent it to me through what's app. I'm going to check the ohms when I finish work
Old Mar 17, 2023 | 11:09 AM
Lee read's Avatar
Lee read
Rs turbo
Old Mar 17, 2023 | 11:11 AM
Lee read's Avatar
Lee read
Rs turbo
That's the engine electrical system and the symbols sorry there's so much.
lee2cossies
47
Nov 21, 2014 07:42 PM
Ed1
13
Mar 10, 2009 04:12 PM
vroooom ptssssh
Apr 1, 2007 09:43 AM
Cawood
Mar 29, 2006 01:21 PM
