Help needed refitting loose dipstick tube.
Old Jan 19, 2023 | 06:39 PM
Carnutter's Avatar
Carnutter
Default Help needed refitting loose dipstick tube.
Hi. When I removed my dipstick tube on my Escort s2, it was a very tight fit and needed to be knocked out. However, a year later and I've finally got around to refit it, but when I put the tube in the block its not a tight fit at all, it virtually rattles around. Does the tube have any sort of seal that I haven't been aware of ? Can anyone please help?
Thanks
Old Jan 19, 2023 | 07:31 PM
BIG LEE's Avatar
BIG LEE
Hi there isnt any seal or anything on tube its just a push fit yours sounds like its loose/worn... you could try some kind of epoxy glue or putty to hold it in place
Old Jan 20, 2023 | 11:47 AM
GVK.'s Avatar
GVK.
I used to use Loctite sleeve and bush retainer on them.
https://simplybearings.co.uk/shop/p3...duct_info.html
Old Jan 20, 2023 | 06:48 PM
ray barker's Avatar
ray barker
Thanks
try making the tube slightly oval or out of shape slightly or even centre punch the outside to put raiesd material on it. tiger seal it tap it back in
CRAIG HAYTER
Oct 17, 2008 10:13 PM
Croniee
Aug 31, 2006 03:25 PM
cressy
Jul 29, 2005 08:40 PM
Stu.H
Oct 10, 2004 11:20 AM
