Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Xr3i efi return of rough running
Old Jan 15, 2023 | 09:37 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Xr3i efi return of rough running
Some time ago my Xr3i was holding back on full throttle and fuel pump was at fault, that sorted the issue now about a 1000 miles later another issue has occurred.
Twice now when starting the car it starts turn of the key fine and seems idle right but once i drive off its holding back and revs bog down unable to get past 2500rpm. If i then stop and turn engine off and restart it works as it should, any ideas?
Old Aug 12, 2023 | 09:14 AM
koopza21's Avatar
koopza21
89 Xr3i
did ya sort it bud? id look at fuel regulator
Old Aug 15, 2023 | 05:44 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Was the fuel pump was a faulty new one sorted now.
RSMK4TURBO
Escort Range
Mar 26, 2024 02:53 PM
tony perth
May 19, 2010 11:01 PM
ford crazy
Mar 29, 2007 04:26 PM
