Heated screen connectors
Old Oct 15, 2022 | 03:52 AM
4x4kiwi's Avatar
4x4kiwi
Default Heated screen connectors
Can someone confirm what type of connectors were fitted standard (90 4x4 cosworth) where the heated windscreen connects to the loom. This is in the engine compartment - both sides - near the bottom of the A pillars. My screen has been replaced previously and has spade type connectors that are in pretty bad shape (corrosion) Doesn't look to be that well insulated or protected from the elements. Would have thought some sort of bullet connector would be more suitable. Thanks David
Old Oct 15, 2022 | 11:56 AM
james kiely's Avatar
james kiely
im pretty sure they are what was fitted from factory
baz walton
Jul 19, 2011 06:00 PM
rotrexlover
12
Jan 30, 2010 05:23 PM
Dan_L
Jun 7, 2009 09:16 AM
Stavros
Nov 27, 2004 02:12 PM
