Cosworth fuel regulator return pipe question
Old Oct 2, 2022 | 01:17 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Cosworth fuel regulator return pipe question
The cossie seems to be running good now I’ve changed the fuel regulator but want to replace the fuel return hose as well.
This is the part I’m after that connects to the return feed on the regulator:
This pipe is just a push fit using this connected. Can that really be right or has something failed?
This is the pipe this connect push fits in to that leads back to the tank:
Does this look right as seems very hap-hazard considering there’s petrol passing through it!
Old Oct 2, 2022 | 01:36 PM
james kiely's Avatar
james kiely
should be fine jimbo as its not under much pressure really as its only the return ,but personally i would prefer a jubilee clip
Old Oct 2, 2022 | 02:03 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Thanks James. That’s good to know. I’m thinking to just replace the whole of the top pipe from the regulator to the lower hose for peace of mind and like you say jubilee clip at both ends.
Old Oct 2, 2022 | 03:54 PM
james kiely
i changed all my fuel lines front to back jim .30 year old original lines dont inspire me with any confidence
Old Oct 5, 2022 | 10:12 AM
Jules44's Avatar
Jules44
10 Year Member
What is the recommended fuel line to use nowadays, as I am thinking of replacing my fuel lines over the winter?
Old Oct 5, 2022 | 06:21 PM
james kiely
i got mine from advocult jules made to measure .spot on service
​​​​​​https://www.advocultmotorsport.co.uk/
_Jimmy_
Aug 1, 2017 05:09 PM
The Underdog
Feb 25, 2013 08:21 PM
coswurv
17
May 15, 2012 06:48 PM
col93saphcos
Apr 4, 2009 10:25 AM
Barry R
Mar 29, 2009 10:26 AM
