Samco Hose from Hart style plenum to intercooler
Old Sep 28, 2022 | 06:47 PM
cossynut2's Avatar
cossynut2
10 Year Member
Default Samco Hose from Hart style plenum to intercooler
Hi Christos hope this helps.
Old Sep 28, 2022 | 09:35 PM
christos's Avatar
christos
10 Year Member
Hi Richard,it helped, thank you. I see that your intercooler pipe and throttle body is aligned.
Old Sep 29, 2022 | 04:20 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Christos, I am not sure how but yes it all lined up. The Work was done at Tremona Garage in Southampton and they always do a good job. The only thing that had to be done was cutting off the outlet pipe on the alloy power steering reservoir and welding it in a different position as it was snagging on the cable bracket.
Old Sep 29, 2022 | 09:27 PM
christos's Avatar
christos
10 Year Member
Hi Richard,
What type of intercooler do you have? Rs500 style or the airtec top feed?
Regards.
Old Sep 30, 2022 | 09:35 AM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Richard,
Regards.
RS 500 style intercooler.
Old Oct 1, 2022 | 01:32 AM
christos's Avatar
christos
10 Year Member
Hi Richard,
the intercooler pipe was modified by the Tremona garage to be aligned with the throttle body or is intact?
Regards.
Old Oct 1, 2022 | 06:27 AM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Richard,
Regards.
Hi Christos, the RS500 style intercooler was not modified at all, it was fitted as it came straight out of the box.
Old Oct 1, 2022 | 12:17 PM
christos's Avatar
christos
10 Year Member
You re a lucky man I suppose because some people have problems with this plenum. I mean they need to modify the intercooler pipe cause its misaligned.
Regards.
Old Oct 1, 2022 | 12:22 PM
christos's Avatar
christos
10 Year Member
Your plenum is a hart or an autospecialists?
Old Oct 1, 2022 | 04:27 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Christos it was bought from A&S auto specialists, i opted for the shiny finish on mine.
davidfordrs
Nov 9, 2012 08:40 AM
SapphyMike
Oct 23, 2005 05:27 PM
rs155
May 25, 2005 12:14 PM
