CVH Cam Timing
Old Sep 11, 2022 | 10:59 AM
JohnDavo's Avatar
JohnDavo
Default CVH Cam Timing
Technical question. Hopefully someone can help me .
In the process of taking head of my 1.6 CVH engine. Manifolds , covers etc are all off, timing belt still on.
The original ford cam sprocket has been removed and there is an adjustable sprocket which presumably suggests a performance cam shaft has been fitted.
The issue is timing marks. There is a punched dot on the face of the sprocket and this does line up with the mark on the head when the crank is at TDC. However the rotar arm is pointing at piston 4 and not 1.
One of the adjustable screws on the sprocket has a blob of paint on it and when the crank is at TDC and rotar at piston 1 the back of the screw does line up with the timing mark on the head.
Don't want to take the belt off until I know what us going on.
Sorry if I have not explained this too well!
Any thoughts on what's going on??
Thanks
John
W4rdy
Fiesta RS1800/RS Turbo
May 22, 2019 08:56 AM
Cowboy24
Jan 30, 2010 06:12 PM
S1 JOHN S1
Oct 30, 2009 01:24 PM
xrmalin
Mar 30, 2007 09:44 PM
Hrsturbo
May 30, 2006 10:04 AM
