No spark sapphire cosworth 4x4
Old Jul 4, 2022 | 03:41 PM
trentt's Avatar
trentt
donkey
Default No spark sapphire cosworth 4x4
Sapphire cosworth no spark... help...
I'm rebuilding my 4x4 , I have spark from the coil when the ignition initially turns on then nothing... any ideas please.
I've a new dizzy cap, rotor arm, new crank sensor, was working when the engine was removed..
Thanks in advance.
Old Jul 4, 2022 | 05:14 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Check the gap on the bottom crank sensor. It is easy to knock them and the gap gets too big.
Old Jul 4, 2022 | 05:34 PM
trentt's Avatar
trentt
donkey
Great, thanks for that, I'll try that next....
Old Jul 4, 2022 | 05:35 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
had it on mine, wasn’t actually out by much but it wouldn’t run.
Old Jul 9, 2022 | 12:09 PM
pectelboy's Avatar
pectelboy
Check the phase sensor in the dizzy . They are renown for corrodeing , had this a few years ago
Old Jul 14, 2022 | 05:41 PM
james kiely's Avatar
james kiely
have you got a god earths to the engine and body?
Old Jul 14, 2022 | 06:18 PM
trentt's Avatar
trentt
donkey
Yeah, good earths, just been told probably got to much paint on the bottom pulley,..
Old Aug 12, 2022 | 10:56 AM
trentt's Avatar
trentt
donkey
Still no joy, ive changed the coil, phase sensor, cleaned the pulley, moved the crank sensor as close as possible, still only sparks when ignition 1st switchs on then nothing from the coil whilst turning it over.. baffled....
Old Aug 12, 2022 | 11:49 AM
cossie2's Avatar
cossie2
Have you tried to swap ignition ampifier?
Old Aug 12, 2022 | 11:56 AM
trentt's Avatar
trentt
donkey
no, ill have to source one, thanks.
Old Aug 12, 2022 | 08:30 PM
james kiely
ave you tried your ignition module up on the inner wing .this supplys your power and earth to your coil
have a look at the wiring for the l8 on this site
http://bigturbo.co.uk/
Old Aug 12, 2022 | 08:36 PM
trentt's Avatar
trentt
donkey
Yeah, tested all the wiring, earth is good and there is a feed going into the module, will order a new one, then thats tge whole ignition system replaced, i have noticed that the fuel pump dont cut out also....???
Old Aug 12, 2022 | 08:52 PM
Monte 140's Avatar
Monte 140
check that the phase sensor plug and the knock sensor plug are on the right ones, on the bracket under the distributor, they fit both .
also check the 2 pin connector for phase sensor inside the distributor, this can also be mounted both ways around.
Old Aug 12, 2022 | 08:55 PM
trentt's Avatar
trentt
donkey
Tried all of those. Thanks.. 👍👍
Old Aug 12, 2022 | 08:58 PM
james kiely
have you changed the fuel pump wiring
Old Aug 12, 2022 | 09:03 PM
trentt's Avatar
trentt
donkey
No, but i have looked into replacing the pump wiring, is it worth doing?
Old Aug 12, 2022 | 09:10 PM
james kiely
a million percent .get a wiring kit for it .
is the relay faulty .has someone bridged it out i wonder.the ecu should cut the pump out after priming unless its running of cours lol
Old Aug 12, 2022 | 09:14 PM
trentt's Avatar
trentt
donkey
Another job to do then, cheers for that. 🤔😁
Old Aug 12, 2022 | 09:35 PM
james kiely
it will save you melting your engine mate .bad power supply equals a weak pump followed by a expensive visit to your engine builder witha melted piston lol
its also worth changing your main wire from the alternator to the battery ,and battery to the starters aswell.they usually at this point have corrosion and are less efficent
James at auto dynamix does all the kits you need
Old Aug 12, 2022 | 09:38 PM
trentt's Avatar
trentt
donkey
Think he is the guy i had the fan loom off...
Thanks for the info. 👍
Old Aug 13, 2022 | 11:25 AM
cossie2's Avatar
cossie2
Phase sensor gap is less than 0.3mm and in correct timed position?
Old Aug 13, 2022 | 11:28 AM
trentt's Avatar
trentt
donkey
Yes.. all good, its going to be something daft i know it is, process of elimination tho...😫😫
Old Aug 14, 2022 | 06:35 PM
cossie2's Avatar
cossie2
...Plugs were wet when you removed them from the engine after turning over?If not check if you have 12v on pin 20 of the ecu..btw you are sure that you havent mixed two connectors for the cps and phase sensor?
Old Aug 14, 2022 | 06:56 PM
trentt's Avatar
trentt
donkey
ive not checked, will do when im home after our holiday,
i swapped the cps and phase sensor over when i couldnt get the pump to cut in, which worked so they must be right.
XaviRS
Jan 19, 2022 11:04 PM
neilsrsturbo
16
May 5, 2009 07:17 PM
neilsrsturbo
May 4, 2009 04:29 PM
rsjohn
16
Jun 1, 2005 06:21 PM
