RS turbo not switching off
Hi guys
I have recently built a mk4 RST. I am having problems with ignition shutting off, I thought this may be an alternator problem so I changed it, still the same issue, I read something about popping the small clip from the alternator,
tried this with ignition of but car running and car stopped, I restarted car with this wire off and switched it of and it all done what it should, where and how do I trace this fault from that small clip wire, does it go to fuse box, relay, ignition confused.com
Any help would be more than appreciated guys
Cheers Kev
Cheers Kev
cosworth_wannabee
Nov 29, 2009 05:37 PM
