Sierra 2000E overheating?
Old Apr 20, 2022 | 06:48 PM
SierraSteve's Avatar
SierraSteve
2000E
Default Sierra 2000E overheating?
hi all,
so my 1989 2000E 2.0l dohc sierra is currently over heating I left it with a local mechanic he was changing sensors ie coolant sensor, thermostat fan sensor, and radiator sensor. to no avail he couldn't sort it so took it to a electrical mechanic he sorted out the fans said that the cable was broken so he ran a new one now the problem is that with all the different sensor's in it now ( not sure if mechanic gave mine back or not as he said he had ones from an old car) it shows that the temperature gauge needle is on the red on the gauge but the car isn't over heating.I put a new ford oem radiator sensor and a new fan sensor ford oem but engine is fine fans kick in when have to but just the temapture gauge is well in tje red anyone know what this could be? thanks
Old Apr 20, 2022 | 07:47 PM
ray barker's Avatar
ray barker
hi there you havnt said anything about the cylinder head thermostat being changed first thing to change ideally. you say the the rad fans cut in which is half the job there supposed to do but do they cut of after a short while with the engine still running if so theres not much wrong.check the water system has circulation that is water coming back upto the exspansion bottle through the smaller pipe. check that the water hoses arnt getting rock hard this could be head gasket gone over one of the water ways compressing the water system. when the engine is running release any pressure in the exspansion bottle be sensible put an old towel over it first undo the cap a minute or two after there shouldnt be hardly any pressure build up so quick if so this also could point to head gasket
Old Apr 20, 2022 | 07:59 PM
SierraSteve
2000E
hi Ray yeah so put in new coolant and water it's all coming back into the expansion tank, I squeezed the top pipe on the radiator and its fine not rock hard and as I squeeze it pushes the coolant t back into the tank so systems not airlocked. I also have a new radiator fitted aswell. I wonder is ot the coolant sensor as I'm looking on line I can see that there colour bands on them I wonder if I swap them for a different colour would that help?
Old Apr 20, 2022 | 10:11 PM
BIG LEE's Avatar
BIG LEE
You will need the correct colour band otherwise gauge wont ever read correct on clocks...
Old Apr 20, 2022 | 11:04 PM
SierraSteve
2000E
hi Lee,
yeah ao this is my problem now, I think as everything else is working just that the gauge is reading to high. I see I can get a green a black and red coolant tempature sensor. Just going to buy all 3 and see which one works best 👌. fingers crossed this is it going to call ford Tommorow and see and if not going to the auto factors.
Old Apr 21, 2022 | 07:26 AM
BIG LEE's Avatar
BIG LEE
You will be wasten your time with ford i think like... if u look on ebay or find someone who knows what colour it is as there is black. green. yellow. red. purple. etc but thats probs 99% the problem it has wrong one in.. not unless someone has put earth to it that will make it got to max aswell
Old Apr 21, 2022 | 03:03 PM
SierraSteve
2000E
yeah so got to check the car the one that's in it is a black one but it could be faulty rang ford they can get a genuine one but will come Monday also order a white one and a green one from auto factors to see will try them out on Monday when ready for pick up.
Old Apr 21, 2022 | 07:36 PM
ray barker's Avatar
ray barker
ask ford what colour is the right one save you buying others but then oem ones might not be coloured
Old Apr 22, 2022 | 05:03 AM
iansoutham's Avatar
iansoutham
OCD Victim
Black is for 1.8 Diesel engines, green is the one you want on a 1989 2000e
Old Apr 25, 2022 | 03:18 PM
SierraSteve
2000E
thanks everyone for the replys so got the new sender from ford all €86 of it 😒 sits between N and O before fan kicks in so happy with that just no hot air now? any ideas 💡 🤔 thanks
Old Apr 25, 2022 | 04:14 PM
BIG LEE's Avatar
BIG LEE
if someone has been messn around with it hasnt it just had a air lock? i no you have had people change stuff etc so water system has had a bit work lately..
Just a air lock in system would explain the temp readn high etc..
i know the gauge says normal but it looks a bit to high to me all the sierras ive had read just after half and stay there
Old Apr 25, 2022 | 05:52 PM
SierraSteve
2000E
yeah unless it's the wrong coolant sensor the one I was given was black but it could be a green one as said above before? what's best way to clear the air block?
Old Apr 25, 2022 | 05:59 PM
ray barker's Avatar
ray barker
normal running temp thats slightly high. no hot air could be air lock. has it got a thermostat in it if it has look for a bleed nipple around the thermastat housing some have them some dont run the engine turn the heaters over to hot leave it set on cold it wont circulate after its circulated properly it doesnt matter. no thermostat no hot air. im assuming you no you have to undo the bleed nipple to release the air untill you only got water coming out of the nipple
Old Apr 25, 2022 | 08:54 PM
SierraSteve
2000E
Hi Ray, so mine doesnt have a bleed nipple so i ran the engine with the exspansion tank open let the fans turn over twice was squeezing all the pipes to try and help any blockages but still the same out come?😮‍💨
Old Apr 26, 2022 | 06:47 PM
ray barker's Avatar
ray barker
did check the engine has a thermostat in it
Old Apr 26, 2022 | 06:49 PM
ray barker's Avatar
ray barker
did you check the engine has a thermostat in it
Old Apr 26, 2022 | 11:01 PM
SierraSteve
2000E
yeah it has one I pulled it out to have a look and boiled it to make sure its opening and closing. wonder is it the matrix thats not working
Old Apr 27, 2022 | 08:24 PM
ray barker's Avatar
ray barker
find the matrix make sure its not been bypassed an old trick if it was leaking. some are right behind the dash. if the two pipes are conected still make sure the change over valve is operating this is the temp heater control its just a simple tap/valve type thing that stops the water circulating through the matrix
fordsteve77
Escort MK 5 / MK 6
Feb 7, 2016 05:29 PM
peteh
Jun 2, 2012 10:29 AM
Rs_Nick
Apr 9, 2010 08:55 PM
radicalroadster
May 16, 2009 10:45 PM
!mouse-oxford!
Sep 28, 2008 04:41 PM
