Crank sensor
Old Oct 6, 2021 | 12:44 PM
Lups's Avatar
Lups
Default Crank sensor
Is it ok to have a voltage on pin 1 and pin 3 when the crank sensor is unplugged I'm getting ting 5v on both need help
Old Oct 6, 2021 | 04:30 PM
james kiely's Avatar
james kiely
i am no expert ,but you have a ground a live and a signal wire .with ignition on you can get up to 5 volts at those 2 pins.i had similar wit my transit last week
Old Oct 6, 2021 | 07:02 PM
Lups's Avatar
Lups
Thanks a lot I was thinking that the signal wire doesn't have permanent voltages
Old Oct 7, 2021 | 07:52 PM
stevieturbo's Avatar
stevieturbo
C**t
And why are you testing like that ?
What exactly is the problem ?
And what voltages may appear can depend on the type of sensor, and simple voltage tests are rarely of much use with a multimeter
s1cab
Apr 9, 2010 05:40 PM
mudgey
Jan 18, 2008 06:50 PM
daveugc
Oct 11, 2007 04:37 PM
SteveB
Jul 9, 2006 03:34 PM
