Fiesta immobiliser bypass
Does anyone know if it’s possible to bypass the immobiliser on a 2008 fiesta st? I’m wanting to get rid of the ignition barrel and all that side of things and just have switches and push button start.
It’s for a track car so the security side of things isn’t an issue
If you want a starter button , you can wire it into the standard loom, just bypass the ignition loom, same goes for an ignition switch, how I did it in my old Mk2 VR6 Golf.
Ideally wire the starter through a relay so it doesn't biurn the button out, I used a Longacre button ffrom DT IIRC. If you keep the steering lock and key it gives a bit of security but if you want to get rid of the stock ignition barrell you can justtape the key to the pats ring.....
Have bumped my old thread about my mk2 https://passionford.com/forum/pictur...f-mk2-vr6.html , it has some pics how i did the starter button panel - if you need any help gimme a shout
xr2i-carl
Sep 21, 2006 07:03 PM
faz10
Ford Mondeo Including ST
Aug 1, 2006 03:12 PM
