Erratic engine idle when switching high beams
Old Aug 28, 2021 | 05:36 PM
cossie2's Avatar
cossie2
Default Erratic engine idle when switching high beams
Hi,
as above what could cause erratic idle/engine sputters on cossie when switching lights or high beams...Checked main earths and alternator all seems fine..
Any thoughts would be great..thanks
Old Aug 29, 2021 | 09:57 AM
Caddyshack's Avatar
Caddyshack
I would run a dedicated earth to the ECU and lights etc. To rule that out, it has to be some noise or an earth. May be worth getting the alternator checked by a specialist too.
Old Aug 29, 2021 | 01:20 PM
cossie2's Avatar
cossie2
Great..thanks will try that.......alternator checks alraedy done....removed the lights relay and than switched on lights..still same..this will take some time to sort out
Old Sep 27, 2021 | 06:05 AM
rayben's Avatar
rayben
Using a multimeter, check the voltage when your car is running and as you turn the high beams on.
Old Sep 27, 2021 | 04:53 PM
cossie2's Avatar
cossie2
.......Thanks...it was earth issue some kind so i have routed new earth wire from engine block to ecu pins 1 and 19......all is well now.....Time for new loom i quess
rog
Nov 7, 2007 02:00 PM
mpales
11
Aug 4, 2007 01:37 PM
ngary
Nov 6, 2006 12:19 AM
adzbelcher
May 17, 2006 04:22 PM
