Low/Poor idle on a 4x4 cossie on brand new engine
Just had the engine rebuilt and done 0 miles, just on driveway at the moment.
Car runs sweet as a nut when warm but u need to keep your foot on the gas till it gets heated up otherwise it cuts out, first port of call i was gonna check would be the ISCV, but how do i do this?
Oh and all the engine sensors were replaced apart from TPS ISCV and CPS.
Hope this helps as otherwise it seems fine.
1 Post
as above, it sounds like you MAY have got one of the injector plugs and the idle vavle plugs mixed up, the car will run very rich and literally piss fuel into the pot thats got the wrong plug on. when u turn the ignition on before u crank it, you should be able to hear the idle valve click several times - does it do this? if not, the idle valve may be stuck shut ,
had this on mine other day.. car ran fine and then i come to a set of lights and idle drops to 300rpm and he cars cuts out
then the bastard thing wouldnt start..
got home and thought hmm might be the alternator so checked that then i checked the iscv after all that..and problem solveed..switched it with the old mans
JoeyBoyden
18-08-2015 05:56 PM
Zoggon
10-08-2015 10:39 AM
