Sapphire Wont Run
Old Aug 15, 2021 | 09:32 AM
Timhysu's Avatar
Timhysu
Default Sapphire Wont Run
Hi first time poster long time lurker, I would appreciate some advise. My brother and I bought a sapphire that needs to be re-shelled ( we have a near perfect shell) this car was bought after spending 8 years in a shed , when they went to restore it and realized the shell was too bad to repair. We got the engine running for a about a 1 min, but need to rig a better temporary fuel supply , to warm it up and see how it runs before we take it out and do a full rebuild. When we went to jump it again the battery was connected in reverse polarity !!!! ( I know ) . So we sent the ECU off to be repaired (Ailvec IoW) and it still isnt running . we have also replaced the , Phase sensor, rotor arm , distributor cap , Plugs, crank sensor, Map sensor , new fuel regulator, ( pump is running and fuel is returning to the temp tank) . We have a spark & fuel coming out of the injectors
what should I check next ??? what else could be fried ?
File Type: mov
Old Aug 16, 2021 | 09:48 AM
Zigu's Avatar
Zigu
10 Year Member
Hello,
I understood that car was running OK, before you connected battery incorrectly? Maybe ECU is still broken, can you try someone else ECU (is known to work), to make sure that not cause the problem?
Old Aug 16, 2021 | 10:22 AM
Timhysu's Avatar
Timhysu
I haven't tried that yet , as i am assuming that EUC was repaired by Ailvec.
sonic7
Jan 27, 2010 05:40 PM
RWD+T4=crazy
Jan 3, 2010 01:25 PM
phil1973
Mar 26, 2007 06:04 PM
mbeblue70
Nov 27, 2005 11:38 AM
cosworthcapri
Oct 26, 2005 05:40 AM
