Theoretical and practical water/alcohol injection system with forced induction
Old Aug 3, 2021 | 12:47 AM
FiestaForever's Avatar
FiestaForever
Default Theoretical and practical water/alcohol injection system with forced induction
I have a question about water and alcohol injection systems, if any one has had any knowledge of, or experience with them, on forced induction air intakes. If you can help, give advice on the subject, or even are from an engineering back ground, it would be awesome.
I am making myself a front mount intercooler that has an integrated water injection system. The intercooler will most probably be connected post supercharger with the air being drawn from the original front mount snorkel on a Fiesta mk6.5 and being blown through it before entering the throttle body, and intake manifold. Would it be better to be drawing the cooled moistened air through the intercooler system instead, or would it matter as the cars intake will also be drawing in the air towards it??
The shell will be of 3mm sheet aluminium, it is light weight but rigid, I cannot weld so I have opted for marine epoxy, liquid weld. The strength and pressure resistance of the epoxy is very high in PSI. The water feed will be from a 5ltr jerry can in the boot, being pumped with a high pressure water pump up to 130 psi to feed the intercooler fluid inlet feed. I have brass compression fittings and stainless steel braided lines for optimal performance of the system. The whole system will be automated with a water level sensor to keep water levels at sufficient capacity, if the water level gets too low the electrical system shuts down automatically, and the water injection stops it is now used as a regular intercooler. The whole system may be connected to a switch in the cockpit.
Is there any specific route that would be easy to run water lines from the rear of the car to the front. Are there many grommets that can be used as such , or is there a safe place that new grommet holes can be drilled on the fiesta mk6.5?
So many questions LOL.
I have acquired the raw materials and hardware needed for the job it is now a case of RnD phase to see what works, and if any improvements can be achieved within its functionality when the prototype is ready.
Your time is appreciated, many thanks, A ford enthusiast.
Old Aug 3, 2021 | 01:52 PM
Rick's Avatar
Rick
You should inject between intercooler outlet and throttle body unless you are direct port, and it should be as close to the intercooler outlet as possible for best mixing.
Old Aug 3, 2021 | 04:56 PM
FiestaForever
Thanks for the comment Rick, very helpful.
Old Aug 3, 2021 | 05:49 PM
stevieturbo's Avatar
stevieturbo
C**t
mmmm WTF.
You've more than a little research to do, as you're all over the place. The advice is do some proper research.
First WTF. "The intercooler will most probably be connected post supercharger"....you cannot be serious ? The only place for a charge cooler core is after the compressor. There is no probably about it.
Second....What do you think would happen to "moist" air if it was confronted with multiple cool surfaces....it will gather on those surfaces and run off. Spraying water internally into an IC core is not the way to do things. Spray it between the IC and throttle. This is by far the easiest option even if there are other locations that can be used.
Third....while some have used epoxies for such things, I would not have high hopes of it holding together for long. Based around that, keep any end tanks small as possible, which is sort of counter productive, but will reduce the forces acting trying to blow it apart. And rather than flat sections, use naturally strong sections like a U shape, etc
And whatever you're actually gluing together, give those surfaces as much surface area as you can for the epoxy to grip.
As for whatever you're trying to do with the wiring and for whatever reason....bonkers.
Some basics, albeit with a proper controlled injection into the intake. This is far above your level or what you need to be doing though, but same principals apply.
Whilst it's novel to try and build something yourself....kits are so cheap, why even bother ? Especially when you don't really know what you're doing.
Buy a kit, install as per instructions. Job done.
Then seek a competent tuner to help optimise the use of it, whilst still remaining safe....if you actually even need it in the first place.
Old Aug 4, 2021 | 03:23 PM
FiestaForever
Originally Posted by stevieturbo
mmmm WTF.
https://www.youtube.com/watch?v=PhShcJZ3JAk
https://www.youtube.com/watch?v=EWFztpnQuPA
https://www.youtube.com/watch?v=7rZ4vYrdTtM
Hello there and thanks for your input. I am happy you decided to make a comment.
I have to be honest I'm not entirely sure why you seem to need the use of a WTF in a thread that is intended to help someone learn. I am asking questions because I am not so clued up on the item in question, it may well be a subject you are very well versed with which would probably be the reason why you are being slightly condescending.
First of all, if hot air is being pulled through the intercooler would it not be being cooled the same amount as if it was being pushed, regardless if it is fresh hot air straight from the charger or after wards it will still be a similar temperature and density, would the air temperature not be the same either way? As this is an intercooler with an integrated water injection system would it really warrant a WTF, as the water is also going to be adding a coolness to the air as well as increase the density, yes we all know that conventional intercoolers might work in a certain way but this clearly is something different which is why it is an item that clearly needs some debate without the extra scrutiny.
Ok so I wasn't being absolutely clear with my design, the intercooler housing will contain, not an injection system but an ultrasonic humidifier/fogger, the air will be in a vaporized state while being pushed through the pipework into the throttle body. Yes water will gather on surfaces and run off, it's what water does, I am attempting a design that will make sure any water that does gather will run back into the tank and not into the induction system. i an any water injection system there will always be some water gathering somewhere, it is the design of that system that allows the water to collect in a place where it cannot be harmful.
The epoxy, I agree, is not an ideal element to the build. The marine epoxy however has the highest tensile strength out of the lot. I was going to glue the corners together with an internal bracket, and then again with an external bracket, which would increase the glued surface area, I also had the idea of using those rubbery type glues that stick body kits to the car to give added bonding. Again I understand that there is no real substitute for a welded metal surface. Perhaps I might hire a welder and some one who knows what they are doing in the future.
What's so bonkers about the wiring? I am no expert, pretty much was spit balling with the whole thing, which is what people do when they ask for advice. The idea may seem a very alien concept to you but then again everything new is a break from the normal.
The video's are excellent, very informative and to the point. I am confident that something positive will arise from this idea, and if I can't put together something useful I can always say I tried and have some experience with tinkering with something original.
No one knows exactly what they are doing first time they try to do something different, yes it may seem that I don't know what I am doing but that's why I am attempting to learn more. it might seem easier to just buy something, which costs over Ł600 for full kit. It is much cheaper to build, plus I enjoy building things and tinkering around, so the journey will be priceless. Might not need it to begin with, but that doesn't mean it should not be attempted.
If every budding entrepreneur, engineer, or inventor took harsh criticism to heart then we would probably not have all the useful technology we have today.
Thanks again for the input stevieturbo it is very welcome.
Old Aug 4, 2021 | 04:31 PM
stevieturbo
C**t
buy some books and do some reading.
Amazon Amazon
Amazon Amazon
Old Aug 4, 2021 | 05:13 PM
FiestaForever
Very interesting books. Wow the price of the one book is over Ł100, if I bought that I must be very dedicated to the cause.
Old Aug 4, 2021 | 05:34 PM
stevieturbo
C**t
The first one is a great all rounder, but been out of print for many years hence it will be a high price second hand.
Sadly no sign of it being re-printed or done in electronic form either
syko2005
Aug 6, 2007 01:40 PM
mikeyrs
11
May 2, 2006 11:56 AM
Garage19
Nov 15, 2005 01:51 PM
CosRush
Oct 22, 2004 07:50 PM
avengerpenguin
Sep 7, 2004 08:43 AM
