intercooler water spray
burning oil
has any one tryed or tested one of these intercooler water spray kits been thinking about making one because it cant be that difficult. but is it gona do any good or make a difference.
http://cgi.ebay.co.uk/Farrell-Interc...QQcmdZViewItem
why not just use a real water injection kit to lower tempratures when required as this will use smaller quantites of water compared to spraying an intercooler, how long are you going to be spraying large enough quantities water to drop tempratures onto and intercooler before it runs out and tempratures rise ?
burning oil
im sure somebody told me that certain model scoobys have a water spray fitted to there intercooler on a manual switch that you just flick when giving it beans to help cool it.
not much use on an ERST really.
burning oil
its perhaps not worth bothering with then. might give it a go when im board at work ive got most of the bits no knock one up just wondered if anybody had tryed it
been thinking of it myself
thinking of taking an aluminium tank which is sealed and bleed some boost into it , force feeding a windscreen washer pump which sprays into a couple of wide spray garden sprinklers
either use a switch in cab or
wire it to my Gotech output or
trigger it via a switch on the throttle
logically , it has to make a difference?
About a year ago in a bored weekend i´ve maded an IC spray for mine.
If you are rolling on the city with external temperatures of 42ºC, it helps a little. But... you need to isolate a lot the water tank, and don´t have really some benefits. You can cold the air for example from 44ºC to 32ºC what isn´t a really big difference. And it warms up again really faster...
Mark RS
12-10-2015 06:01 AM
rsguy
44
29-09-2015 03:29 PM
