Cosworth wheels
Old Jul 22, 2021 | 11:11 AM
dal3door's Avatar
dal3door
Default Cosworth wheels
Hello can anyone help me in this matter I want to fit 17in wheels on my 3 door cosworth and I do not want to cutback the archs and they also have fit over 6 pots brakes with 335mm discs at the front and 4 pots with 328mm discs on the rear what I think I have come up with that will also look good as well is
7.5j x17 with an offset of et35 with tyres of 205/40/17 on the front
8.5jx17 with an offset of et30 wth tyres of 235/40/17 on the rear
I you own a 3 door cosworth do you think these would fit or even better what do you run on your car
thanks very much for any help given
Old Jul 23, 2021 | 05:45 PM
cossynut2's Avatar
cossynut2
10 Year Member
An important thing ,is it standard ride height or lowered as this will make a difference.
Old Jul 23, 2021 | 05:58 PM
dal3door's Avatar
dal3door
I am using koni adjustable shocks and Bayjoo road spring which are not much lower than stock spring just uprated
Old Jul 24, 2021 | 08:52 AM
cossynut2's Avatar
cossynut2
10 Year Member
The combination you are planning on fitting should be ok without needing to roll the arches.
Old Jul 24, 2021 | 12:57 PM
mullz's Avatar
mullz
I tried 205 40 17's on the front of mine. They looked horribly stretched so I went to 215's. They then rubbed on the arches so I had to modify them. Beefing up the front suspensions bushes helps as this stops the wheels moving back relative to the body when braking. Really, 205s on a 7.5" wheel look awfully stretched.
Old Jul 24, 2021 | 03:58 PM
cossynut2's Avatar
cossynut2
10 Year Member
Lowered 30mm, 215/40/17s front and back with rolled arches . Koni adjustable on the front Bilsteins on the back both with lowered springs.
Old Jul 24, 2021 | 05:03 PM
mullz's Avatar
mullz
Looks great but the front arch extensions on the 3 door really do limit the space.
dal3door
Oct 22, 2018 03:23 PM
paddy heffernan
Nov 25, 2012 03:47 PM
jamieRST
Sep 3, 2009 06:03 PM
Vic
13
Aug 9, 2006 01:31 PM
13
Feb 23, 2004 10:54 PM
