ABS
Old Jul 21, 2021 | 10:36 AM
Cosworth48's Avatar
Cosworth48
Default ABS
I have a problem with the master cyl on my 1986 Sierra Cosworth, the system pressurises ok but no fluid comes out of the master cyl port that supplies the rear brakes anyone experienced this and can shed any light.
Any help appreciated.
Thanks.
Old Jul 24, 2021 | 08:00 PM
Is the ignition switch on when your wanting brake fluid to come out the rear pipes??
Old Jul 24, 2021 | 09:22 PM
Cosworth48's Avatar
Cosworth48
Default ABS
Hello Glenn,
Thanks for the reply, I have diagnosed the fault, the piston is seized in the housing that the brake pedal rod operates on, I have had it apart and freed it off so now hopefully the pedal has enough stroke to feed the rear brakes, time will tell.
Happy Daze!
Kind regard,
Peter.
original
Apr 28, 2026 05:20 PM
KW-rscos
May 14, 2013 02:49 PM
kieran_macca
Nov 3, 2012 08:00 AM
savie62
Technical essay Archives
Apr 12, 2012 08:52 AM
MARKYMARKONE
Jan 20, 2005 07:25 AM
