What are these objects?
Old Jun 6, 2021 | 07:13 PM
FiestaForever's Avatar
FiestaForever
Default What are these objects?
Hello peeps, I would like some help identifying these objects on a ford fiesta mk6 engine. If you can help, that would be awesome and you would be doing your bit in the helping to make a project with adding a supercharger to an engine come into fruition
, oh thank you muchly
What is hole A?
:Does it contain a tap within, can it be used to put a threaded bolt into it?
:If it has no thread within can it be tapped with a tap, to be able to fix a bolt to it?
What is the part B?
:Self explanatory title here, what is the specific part? Is it the power steering pump?
:If you know what the part is can you give an oem part number for this please, so I can check just how it fixes to the rear of the engine block?
Old Jun 9, 2021 | 07:22 AM
Hole A could be for an idler that might be fitted to other engines but I wouldn't worry about it too much. It looks like your auxiliary belts are the stretch belt type so they don't need a idler/tensioner.
Part B looks like a power steering pump to me.
Old Jun 9, 2021 | 05:15 PM
FiestaForever
Hello Glenn thanks for the reply. Would you think that the hole A could contain a thread so I can use it as a bolt hole to bolt a bracket onto?
Old Jun 15, 2021 | 01:07 PM
I would of thought so. If not its only Alloy so it should be easy to tap a thread into it.
Old Jun 15, 2021 | 10:34 PM
FiestaForever
Brilliant. Thank you very much for the help. KUDOS
Old Jun 16, 2021 | 08:38 AM
Anytime pal.
Dearo
Feb 8, 2012 01:15 PM
xxTWINNYxx
Mar 6, 2011 08:32 PM
Stu @ M Developments
24
Oct 9, 2008 06:35 PM
D19 STE
Mar 12, 2008 03:10 PM
