Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
What are these objects?
Old Jun 4, 2021 | 12:10 AM
FiestaForever's Avatar
FiestaForever
Default What are these objects?
Hello peeps, I would like some help identifying these objects on a ford fiesta mk6 engine. If you can help, that would be awesome and you would be doing your bit in the helping to make a project with adding a supercharger to an engine come into fruition
, oh thank you muchly
What is hole A?
:Does it contain a tap within, can it be used to put a threaded bolt into it?
:If it has no thread within can it be tapped with a tap, to be able to fix a bolt to it?
What is the part B?
:Self explanatory title here, what is the specific part? Is it the power steering pump?
:If you know what the part is can you give an oem part number for this please, so I can check just how it fixes to the rear of the engine block?
Old Oct 22, 2021 | 06:26 PM
MarkRobins's Avatar
MarkRobins
What is hole A?
What is the part B?
Wow! So nice
montaser
Ford Fiesta
Apr 30, 2016 06:12 AM
FARD Fiesta 1600s
Sep 21, 2008 11:26 PM
rsdan123
Mar 19, 2008 12:14 PM
eddy_wright
Dec 8, 2006 12:24 AM
