Out in the old cossie today and had an issue appear. She is a 4x4 well was before it became 2wd.
Jacked her up and removed rear casing of box to my delight if a broken transfer chain.
Does anyone know where to buy new chain from?
The gears are drop down gears to run a 3.9 rear diff, so only have 30 links instead of the standard 33 links.
Also does anyone know how to check the chain if worn?
Thanks.
Casing opened and out pops the evidence that caused car to become 2wd,. Other chain is unknown condition have it as a spare.
IIRC some one bought remaining stock of those chains from Ford years back, so should not be available new anymore. But perhaps companies like Bara, Oppliger etc. might have them? I don't remember if it was official way of testing them or not, but you can put the chain on a desk, and there should be gap (few millimetres I guess) beetween the resting top part, and bottom part which lies against surface.
