Sierra front wheel hub carriers
Old May 25, 2021 | 06:00 AM
MARLIN's Avatar
MARLIN
Default Sierra front wheel hub carriers
Hi
Hope I don't upset any of you Ford enthusiasts. I have a kit car with Ford Sierra running gear (around 1983 era) fitted. The right hand side front axle carrier (where the track control ball joint and track rod end tapers are) is in a bad way. I can't locate a replacement 1983 carrier so was considering fitting the same item from a later vehicle. Does anybody know how the carrier changed dimensionally through the years?
Regards Phil
Old Jun 11, 2021 | 09:39 PM
stevieturbo's Avatar
stevieturbo
C**t
Id imagine nearly all of them would be the same for 2wd cars
Old Jun 13, 2021 | 08:55 PM
lacey's Avatar
lacey
I have some off a 2wd 87/88 mk2 Sierra
Old Jun 14, 2021 | 06:26 AM
MARLIN's Avatar
MARLIN
Can you see the part number cast into the carriers. I'd be interested in buying these off you if you want to get of them. Not sure how to personal message on this forum.
Phil
steerfromdarear
Jan 29, 2014 08:26 PM
