Bottom end rebuild
Hi all, I need to do a bottom end refresh, so was wondering about what you would use, engine has done 139k now so getting a little tired and noisy its only a stage 1. Engine is an old 2wd from 88, it still has the original mahle pistons in with the piston slap.
It will have the next bore size up from standard.
I will need the following parts so want to know what everyone tends to use nowadays.
Pistons
Oil pump
Bearings
Anything else that I will need?
Pistons
Oil pump
Bearings
So what brand of piston is the one to use nowadays?
wozz
Jul 9, 2009 08:23 PM
twinkle_2k86
Nov 21, 2005 02:42 PM
