Sierra 2.0 dohc
Hi can anyone on here confirm the correct clutch diameter for the 2.0 dohc ford sierra with the mt75 gear box? I have fitted on from the motor factors and it don't seem to be right. Have a very long pedal and clutch slips. The clutch i fitted is 215mm diameter.
THANKS
THANKS
THANKS
THANKS
The clutch for siera is 215 mm diameter!
And for mondeo mk2 is 210 mm diameter - ford logic.....
