Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Drive Shaft Oil Seal - MkII Focus
Old Mar 31, 2021 | 10:20 AM
chrisxbates's Avatar
chrisxbates
Default Drive Shaft Oil Seal - MkII Focus
Hello,
My Girlfriend's Ford Focus (Mk II 2008 1.6 Zetec Manual) has a gearbox oil leak from the Right drive shaft oil seal. I want to change the oil seal. I believe the gearbox is the IB5 type.
Do I have to detach the driveshaft from the wheel knuckle/hub to do this ? I would prefer not to do this if at all possible.
If I do not have to detach the driveshaft from the wheel knuckle/hub, do I have to detach the steering track rod end, for extra mobility for the wheel knuckle/hub.
I plan to detach the lower arm from the wheel knuckle/hub, prior to removing the driveshaft from the gearbox.
Thanks
Chris
st220kyle
17
Mar 24, 2019 11:27 AM
phil_rs
Jan 31, 2012 03:07 PM
daviddunlop83
Apr 20, 2009 10:03 PM
EscortMatt
Jul 11, 2006 09:37 PM
AndyKam
12
Feb 20, 2005 09:24 PM
