Cosworth 4x4 ABS problem
Hi guys,
the problem my car has developed is
when I drive and use the car the ABS and red brake light come on simultanously about every second time
I use the brakes.
I checked the system stationary and if I pump the pedal the lights come on and at the same time I hear the
pump starting to run. So I think there is a pressureswitch that is not working as it should.
This switch should activate the pump before the pressure becomes too low
Can someone point me in the right direction
Robert
I use the brakes.
Robert
The pump runs about every second time I press the pedal, so I don't think the accumulator is faulty.
I think the pump should be running earlier than it does now, so I suspect a pressure switch is faulty,
but I don't know where to start
englandbrad
Jul 6, 2009 06:34 AM
