2.1 zvh turbo escort mk4 kangarooing on boost and bogging down
Old Mar 9, 2021 | 09:46 PM
Zvh2.1's Avatar
Zvh2.1
Default 2.1 zvh turbo escort mk4 kangarooing on boost and bogging down
Hi all
I got the above car
sometimes when driving in high revs just before changing gear it will back off and start kangarooing as if it’s over boosting
thought I sorted it by removing the adjustable boost valve but still does it and now sometimes when it starts doing it I can not get high in the revs without it bogging down and running Poo but take it back down to cruising speed and all fine until
I bring revs back up
leave it a few miles and can get up the revs again until another few high rev runs and does the same
have checked all pipe work etc and all ok
plugs good compression good
any advice massively appreciated
thanks
Old Mar 10, 2021 | 10:04 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
are you sure it's not just a hard cut rev limiter on the rotor arm? i remember on my xr3i i tried a few arms, some were soft cut and some just cut the power completely until it dropped a few hundred rpm
Old Mar 11, 2021 | 05:08 AM
haz87's Avatar
haz87
Its on coilpack by the looks of it so wont be dizzee arm.
If its bogging it sounds like it might be overfuelling. Have you got an AFR gauge/checked it with a gauge? Did you have the engine checked after removing the adjustable valve? What boost is it running?
Old Mar 11, 2021 | 07:05 AM
Zvh2.1's Avatar
Zvh2.1
hi
yes it’s coil pack
not got an a/f gauge but will have to get 1
The adjustable valve was fitted by me as wanted to turn boost down as thought that might be problem but was not so just removed it
if I remember right it’s running around 0.5 bar according to the gauge
Old Mar 11, 2021 | 07:15 AM
Zvh2.1's Avatar
Zvh2.1
hi
its a coil pack set up so no rotor arm
most of the time it’s fine tho and can get it in the high revs and boosting well
but then randomly it will do it and then bog down some times after that not allowing me to Rev high at all
Been told to fit a air fuel gauge and change fuel filter and fit an adjustable fuel pressure reg and check crank sensor so far
Adam.
14
Apr 10, 2012 07:31 PM
Marts
Jun 17, 2009 11:36 AM
creedy
Dec 30, 2005 05:55 PM
kevsrs
Nov 5, 2005 10:15 AM
gavintwopies
May 5, 2005 06:45 AM
