Engine swap questions
Old Mar 1, 2021 | 09:01 AM
Nickss's Avatar
Nickss
Default Engine swap questions
Hello i m looking to buy a first car in an extremely tight budget and an option is the 1.6 sierra. But i want something a bit more powerful newer and economical. So i want to know if i can fit a 1.6 focus mk1 engine in the sierra transmission. I have read that the 2.0 bolts up to the mt75 but does the 1.6 bolt on?
Old Mar 1, 2021 | 11:24 AM
big_wasa's Avatar
big_wasa
If its the 1.6 Zetec Se it won't bolt up directly to the mt75 or the t9. You can get a bell housing for the t9 but "I think" the crank needs drilling for the spigot bearing. It's not going to be cheap or very effective dragging a Sierra around.
For Se info look at a firm called Shawspeed.
A 1.6 Zetec E won't pull thre skin off a rice pudding but would be cheaper and easier to install.
A 1.8 Zetec E would be a much better bet. Better still the 2.0 but they are getting harder to find.
Neither are going to feel special in a Sierra with out a boost in torque.
Old Mar 1, 2021 | 05:18 PM
XR2's Avatar
XR2
Depends on which 1.6 Sierra he has. The (quite rare) 1.6 CVH should have the same clutch bellhouse pattern as all Zetecs!?
Fordnewbee
Dec 3, 2019 07:56 AM
Rhys mk1fez
Oct 19, 2014 08:38 AM
Smiffy2k8
Ford Focus Range
Jan 28, 2013 12:34 PM
Fociwill
Ford Focus RS
Jan 28, 2010 03:14 PM
Ryan_3
13
Jan 7, 2008 12:28 PM
