Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
RS V st170 Alternator
Old Feb 20, 2021 | 12:29 PM
t230's Avatar
t230
Default RS V st170 Alternator
As above
The RS shell i built up was converted to st170 climate control etc -front heated screen - blah blah - everything works fine - but massively fluctuating voltage 13.8 - 15.0 at idle - idle not affected drastically - although where revs should drop between gears stays high - tried -63, 065 and 075 battery same result- so my question(s) : Whats the difference between st and rs alternator apart from amps ie fitment - case of just changing pulley over?
With rs alternator problem is worse with sub/amps etc ...no charging problems or starting probs...starts first time everytime ....can iget a higher amp alternator - cant seem to find apart from St or diesel cheers guys!
Old Feb 26, 2021 | 10:41 PM
t230's Avatar
t230
Sorted after repairing smart charge loom connector from alt to ecu all good now !
red sport
Ford Focus ST
Dec 2, 2017 06:06 PM
caprizetec170
Mar 9, 2014 02:10 PM
sonic7
Jun 13, 2011 11:47 AM
dazz25
Ford Focus RS
May 28, 2009 10:11 AM
Robs Frst
Apr 23, 2009 03:37 PM
