Alarm problem
Old Nov 23, 2020 | 08:55 PM
Jmck74856's Avatar
Jmck74856
Default Alarm problem
My 1996 escort rs2000 alarm keeps going of anytime a door is opened for about 2 or 3 mins how do i solve this
Old Nov 23, 2020 | 10:29 PM
GVK.'s Avatar
GVK.
Could be a faulty switch, need to put alarm into test mode and then go around and see which switch doesn't work.
Been a long time but if I remember correctly press the bonnet switch 8-10 times then you will hear the alarm horn beep to show its in test mode.
Then go around open/ close each door and work each lock and it should beep every time a good switch is actuated, if it doesn't beep there is your problem.
The door lock barrels themselves have switches too
More info
http://www.rs2000-16v.co.uk/newsitefiles/alarm.htm
ford2222
Dec 23, 2014 07:42 PM
deathrider666
Ford Mondeo Including ST
Jul 22, 2013 05:05 PM
20legend_20
Jan 13, 2011 01:05 PM
jammy86
Dec 28, 2009 08:29 PM
mintlaugh
Oct 3, 2006 04:41 PM
